820-3115 low ppbus_g3h, no obvious short (until you look carefully)... green light ok
george-a
Hi guys,
Having UC this one (was pretty messed up) I replaced U6990 and got a green light (at least thats how I remember it and in a hurry noted on paper - since this board was written off for a couple of months) but the system is still dead.
Measuring around I discovered that my ppbus_g3h was 1,2V, measured around a bit more and I decided to replace the isl6259 which brought the ppbus_g3h to 4,12V (I should have kept measuring as you ll read further down).
L6995 measures 0,070 in diode mode but when removed the right side (pin1) measures 0,58x. I thought maybe there is a short somewhere and I applied 1V as per Louis (http://advancedreworks.com/forum/arc...hp/t-1476.html) on the 0,070 side (brain activity has considerably slowed down by now) but nothing gets really hot and thats expected from a few milliamps draw.
EDIT: as per this thread: "https://www.rossmanngroup.com/boards/forum/board-repair-troubleshooting/1013-mbp-820-2936-with-short-to-ground-on-pp3v42_g3h-and-no-orange-or-green-light" I must inject 3.4V which also makes sense - will do this and come back soon. Please read on...
F7040 diode mode is 0,434.
Finally a few minutes ago I just measured short (diode mode 000) at pin2 of ALL THREE L7510, L7520, L7550 (raised one side from the pad with the soldering iron). Is the CPU fried? Should I inject voltage here?
Should I just name this sucker "donor"?
Thanks for any input guys.
George
CPU coils show very low value, especially for i7 (001)...
Peel off the black sponge near BIL connector.
Usually bad cap underneath, going to audio area; one of C6400/3/5.
