820-3115 - Need clean ME SPI ROM
Alan.L
original u6100 chip was damaged by corrosion, trace to pin 8 (pp3v3_sus) was missing. i fixed with a jumper.
i was not able to use the original chip, i then used another u6100 from a donor board and booted fine.
can someone make me a clean ME with serial number and Fsys?
C02JWW4QDTY3
cheers
Alan.L
file is ok now for some reason.
i've used the ROM but Fsys need patching otherwise will say system serial number unavailable in ASD. however the serial works fine in OSX
i've no idea how to patch Fsys :(
also sensor tests are missing.
Donor board doesn't have clean ME region!!!
Medusa 2 can fix the checksum error.
Normally entire Fsys is moved from backup to new BIOS.
But you don't have a backup...
Alan.L
i know, i was thinking using it then make it clean ME region
ohh i do have original rom but i dont trust it, the chip dont work on the logic board. the minipro can read it alright most of the time. give me a sec.
