820-3115 No audio devices.
deephouse
Hi, 820-3115 with liquid damage, does not detect audio devices. No input/output devices found. I can't find out what the problem is. There was serious damage around the U3300, and I had to put in several bridges to power the L6611 and R6610.Maybe something in the layers themselves is hurt!? I'm asking for help.
LG
U330 is not related with audio device; is just power switch for SD Card.
Check for corrosion U6200/01 area.
No audio devices at all on System Report?
deephouse
There is no sound at startup, the system does not detect any audio devices. Power supply feeds 4.5v in on the audio codec chip. To be sure, I replaced the U6200/01. I think everything is present in U6201
I expect some small resistors, or coils corroded.
Check inlcuding for corroded traces.
Check all powers around audio codec and its reset signal too.
deephouse
I solved the problem - the motherboard is rubbish.
I found that the connection was broken with U1800-R6211 / HDA_SDIN0.
Thanks for the help.
