820-3115 No Backlight Killing Me
felixthecat
No beep at all on all the Pins you asked.... I should just go run this over with my SUV a few times, pick up the remains and burn them and then bury it.....
Just for the heck of it I replaced C9782 as well...
Pin 3 now shows 4v still no backlight....
jadao
What voltage do you get at
pin 2 of R9789?
pin 1 of R9731?
pin 2 of R9731?
What resistance do you measure on R9731?
felixthecat
pin 2 of R9789 - 12.03v then drops to 0.1
pin 1 of R9731 - 0v
pin 2 of R9731 - 0v
What resistance do you measure on R9731 - 301K
felixthecat
Thank you for the suggestion, I didn't even notice the through the hole to other side was bad :-/
I have the 3v on pin 2 of R9731 still no backlight. I'm beginning to wonder if this board is just hopeless
You fixed a bad trace. Now you go back to step 1 and check voltages again on Q9706 and see if it at least fixed that.
felixthecat
Q9706
Pin 1,2 - 12.5v
Pin 3 - 4.3v
Pin 4,5,6 - 12.5v
BKL_EN - 3.1v
BKL_PWM - 3.2v
BKL Line LCD Pins 2,3,4 - 3.3v Pins 21,22 - 0.6v
