820 3115, no green light
"SMC_BC_ACOK" needs to be steady 3V (or close value); no need o-scope to check it.
You must put SMC_ONOFF_L to ground for an instance only, like when pressing power button; do NOT maintain ground contact.
Noguinfor
I don't see any reaction! =(
i test with power supply and when i press the power button only consume 0.018A to 0.020A.
already replace SMC for one i know it's working!! and same history,,
could be PCH?
I really needed this board repaired. so I because insist a little more .. thank you
Noguinfor
PM_PWRBTN_L the only reaction i see it's the signal goes to 0v when i put SMC_ONOFF_L to ground for an instance.
PM_RSMRST_L = 0V
PPBUS_G3H and 3V42 are stable's! And in diode mode compare with a working board and shows same values! i still haven't green light with original charge only with fake!
i have a perfect working board with me. it's possible we know if PCH is working well with measure points ??
1 question we know PM_SLP_S4_L and PM_SLP_S3_L bought are pulsing, what does it mean?? i would like to understand!!
Noguinfor
U7939
pin1- PM_RSMRST_L = 0V
pin 2 - GND
pin3 - N.C - 3.3V
pin4 - S4_PGOOD_CT = 1.4V
pin5 - PP3V3_SUS_PWRCTL - 0.04V
pin6 - PP3V3_S5_PWRCTL - 3.3V
Don't star via SMC bypass mode!
Noguinfor
No i have PM_SLP_SUS_L = 3.3V stable!
i noticed PP5V_S3 in diode mode i have 424v compare a working board i have 0.138v ... the problem can be here..already replace again this 2 components q7261 and q7260. i already check the rails and no one missing! can e a component fault??
thank you
Noguinfor
I do not know how to tell you this but while I was doing the measurements on Q7820 / 22, the comes to life without replace any component!!! i use a power supply to test boards, and when i see the current up to 900mA i'm WOW!!! This board repaired itself. in this type of situations what do you do ?? I have a lot of fear in these situations because the probability of coming back is high!
Noguinfor
Nice one Mr.Vali!!! Thank you for your patience and insistence. Without your help I would not be able to repair this mac. you are a legend! in addition to being repaired I learned from you .. thanks one more time
