820-3115, no image on screen Black screen
yobad
820-3115 has backlight and no image
working with an external screen
replaced j9000
PP3V3_LCDVDD_SW_F is present
Check L9080 first.
Next, check diode mode on all LVDS DATA lines to ground; w/ and w/o LCD connected.
Also try known good compatible screen.
yobad
I tried new lcd always no image but some color is floating.
L9080 is fine 3.3v on both sides
Pin
6 .662
7 .664
8 .693
9 .695
11 .696
12 .695
14 .671
15 .644
17 .671
18 .644
Did you try compatible screen for sure?
Can you explain "color floating"?
Compare diode mode readings w/ and w/o screen connected.
You can get some difference, but values should be similar on each pair.
