820-3115 no power
Secondary voltages should appear even without SPI chip soldered; less the CPU ones.
So, PM_SLP_S4_L should pulse at least; check that.
Post again all the signals mentioned in the previous posts...
Kyle93
PM_SLP_S4_L does not pulse at all
PM_SLP_SUS_L 0V
RTC_RESET_L 3.482V
PCH_SRTCRST_L 3.481V
PCH_INTRUDER_L 3.195V
PCH_INTVRMEN_L 0V
SMC_ONOFF_L 3.487V
Kyle93
Noticed there was a short on PP5V_S5.
Soldered SPI chip back on for testing. Replaced U7801 and U7200 and now PM_SLP_S4_L is pulsing at 3.3V with a quarter fan spin every few seconds.
Do I just need new ME region now? If so can someone provide?
"PM_SLP_SUS_L 0V"
PCH doesn't want to set it high.
And here is the reason.
"PCH_INTVRMEN_L 0V"
This signal should be high now, if machine tries to start.
"PM_SLP_S4_L is pulsing at 3.3V"
Check if all voltages controlled by it pulse too.
Do the same for PM_SLP_S3_L.
Also look if ALL_SYS_PWRGD pulses.
Kyle93
suddenly lost my old voltages since I last checked this board. I have nothing for PM_SLP_S4_L now and no more quarter fan spin.
pp3v42 3.42 V but no green light PPBUS_G3H only 1.060V now
what to check next in this case?
Kyle93
replaced q7085 now back to quarter fan spin
all voltages for PM_SLP_S4_L are pulsing along with PM_SLP_S3_L and ALL_SYS_PWRGD
Kyle93
I have the fluke 15b+ multimeter and I do not believe it supports MHz oscillation. Is there another way to check?
Check if all the voltages from page 72 try to appear.
Also check all SPI termination resistors and traces around U6100.
