820-3115 no power
Kyle93
Arrived with minor liquid damage on U7941 Q7335 Q7330 Q2815 and Q2800. Replaced everything but still have 15V onPPBUS_G3H. Fan spins a couple seconds then stops then continues e.t.c
Replaced Q7030 Q7035 and U7000 at the same time but still 15V on PPBUS_G3H
What should be tried next?
Really strange.
Post again all basic voltages for U7000; pins 1, 2, 3, 5, 6, 9, 12, 13, 14, 15, 17, 19, 20, 27.
Keep F7040 removed.
Kyle93
u7000
Pin (1) 0.014V (2) 18.17V (3) 4.3V pin (5) 2.9v (6) 3.4v (9) 0.028v (12) 3.4v (13) 3.4v (14) 3.4v (15) 0.045v (17) 1.6v (19) 5v (20) 5v (27) 18v
Kyle93
Readings go from 15.70V at times to 4.45V at other times on L7030 even though there is a constant 1.6v on pin 17???
Pin 17 is directly connected to L7030.
At least should be, through 0+0.01 ohm=10 miliohm in total.
How can you get different DC voltage reading then???
BTW, measure ALWAYS DC voltage on the output pin of a coil from a buck-converter.
