820-3115 no PPBUS_G3H
grmacs
ISL
1-0
2-16.5V
3-4V
9-0
12-3.5V
13-3.48V
14-3.5V
15-0
17-.3V
19-5V
20-5V
27-16.5V
17/18- 2.9 ohms
27/28-20.0 ohms
PPBUS_G3H- .28V
diode ppbus G3H to ground - .225V
First bad readings at ISL, replaced got current values, had short on PPBUS_G3H at q7035 that appeared later on working on things, replaced q7035/30 and u7000 one more time. Values at ISL still same and still no PPBUS G3H
0.225 on L7030 is not good, if Q7035 is original; check diode mode inverting probes too.
Remove F7040 and check voltage at L7030.
Check again diode mode with F7040 removed.
You should get 0.400-500 at L7030, with red probe on ground; OL with black on ground.
