820-3115 - Quarter Fan spin
MUUK
Minor liquid damage.
Fan spins for a couple of seconds then repeats.
PP5V_S3 jumps from 0.2 to something as fan goes on and off
PP5V_S0 jumps from 0.6 to something as fan goes on and off.
Cannot see anything on either of these lines that is suspicious.
Diode mode PP5V_S3 0.430
Diode mode PP5V_S0 0.389 (matches donor)
Wanted to see if it was the S3 or the S0 causing the issue. Removed Q7860. With Q7860 removed PP5V_S3 is 5v.
Suspected Q7860, replaced it.
Board turned on for 30 seconds with normal fan.
Unplugged, waited and tested again - Back to same problem, quarter fan spin.
Vcore when quarter fan spinning is not coming on.
Begin to suspect U7400 ?
Appreciate any help as always.
MUUK
Both look and measure ok (180K and 150k).
On pin 2 (input) i get a totally steady 12.56v
On pin 1 (both, seperatley) I get 12.33v, which jumps (very quick change on multimeter - decimal point jumps about with fan pulse)
MUUK
ISL looks fine. 4ohm and 20.4ohm on the readings.
Do get pulses at the big coils PP1V5, PP5_S3 etc. Nothing on CPU ones.
No change in SMC bypass mode.
Thanks again.
MUUK
If i heat Q7860 it will boot a whole OS and run until shut off. I tried replacing Q7860 again, and all the surrounding components.
MUUK
Thanks, Was just looking at Q7802. Replaced it (have already replaced R7860/62)
Real head scratcher.
