820-3115 video issue
jgraffis
I've got this 820-3115 that doesn't post video on internal display. video works great threw the thunderbolt port. i can see that the back light is very dim and no picture. the machine did have very minor liquid damage around c3888 and r3880.
ppvout_sw_lcdbklt-- 27v
L9080 pin1 and 2 are 1.4v
pp3v3_lcdvdd_sw is 3.32v
pp3v3_s0 3.32v
i have changed the lcd connector as i had the pins smash and touching each other.
not sure what I'm missing any ideas would be great.
27V is sufficient for normal backlight.
You probably have problem with LCD connector, video cable or display itslef...
However, check return resistors.
NVRAM reset done?
screen is black. have already changed connector, lcd cable and screen already swapped from known work machine. ill check resistors though. smc was reset and pram.
pin-1 0.0
pin-2 0.413
pin-3 0.413
​​​​​​​pin-4 0.311
pin-5 0.312
pin-6 0.488
pin-7 0.456
pin-8 0.457
pin-9 0.503
pin-10 0.00
pin-11 0.00
pin-12 0.056
pin-13 0.00
pin-14 0.00
pin-15 0.008
pin-16 0.00
pin-17 0.060
pin-18 0.106
pin-19 0.00
pin-20 OL
pin-21 0.565
pin-22 0.565
pin-23 OL
pin-24 0.606
pin-25 0.605
pin-26 0.604
pin-27 0.602
pin-28 0.602
pin-29 0.603
pin-30 OL
