820-3126 none usb port works
andrespi
Hello, This imac, no usb ports works, I have measured
PP3V3_S3_USB_HUB=3.3v
VBUS IN ALL PORTS USB=5V
The strange thing that does not turn on light when I connect usb mouse, It should turn on if it has 5v or I'm wrong
What measurements do I do more?
andrespi
bluethooth is not working, camera and sd I do not know why I have no way to test since mouse does not work
Any history available?
External USB ports, bluetooth and SD card go through USB Hub 1/2.
Camera goes directly to PCH.
If 5V present on USB ports, then check L4601/11/21/31 continuity and diode mode to ground.
You can remove and bypass U4650.
Check FAULTx* levels of U4600/20.
andrespi
l4601/11/21/31 all measure continuity, diodo mode in all 0.69. How do I bypass u4650?
L3559, C3543/42 are burned
andrespi
excuse me, a little sulfate on L3559, C3543/42 It was already eliminated but a problem persists. How do I bypass u4650? How do I measure with a multimeter or oscilloscope FAULTx* levels of U4600/20?
Forget U4650 at the moment.
You should get another port working at least.
Check if both U3500/600 get correct power.
Voltage is splited with two coils for each chip.
Did you check if all power rails are good?
Strange to have both chips damaged, but you can try changing them from donor board.
Compare diode mode readings on USB data lines with good board.
andrespi
I have 820-2641 board good, I see the board the same.L4621, l4601,l4611 usb data modo diode 0.69 is the same valor than board 820-3126 board bad usb
