820-3208 cuts out booting from ASD OS but runs fine from ASD EFI
cwalex
I have a liquid damage logic board. One of the RAM chips was badly corroded so I reballed it. The macbook will boot and pass ASD EFI but if I try to boot any OS, either ASD or a USB test drive it just cuts out. Any ideas where to start?
Cheers,
Alex
cwalex
I had a hard time finding one for this model. Found one on the internet and flashed it, same issue remains. I can't be sure this is a good BIOS image though.
cwalex
I don't have a donor board for this model. Are you saying that you think the ME region may be what is causing this behaviour? If so, I could clean the ME region.
cwalex
Turned out to be the trackpad. Cleaned up some corrosion on the keyboard connector and reflashed the original EFI back and it's now booting up just fine. ASD passes. Thanks for your help anyway.
