820-3208 - no fan spin
Mentioned signals appear much later...
PCH should first release SLP_SUS and next SLP_Sx, after got PWRBTN reaction from SMC.
"with L7260 removed there is 2.6+v at both pads"
What???
The coil is a part (important) of buck controller!!!
Any voltage measure without coil is a non-sense...
Change U7201 and Q7260; pay atention to R/C7264.
jpadie
Yes - it's very odd. the voltage stays the same whether the coil is there or not. makes me very suspicious of U7201. but .... there is no enable inputer on U7201 either
jpadie
U7201
mostly at or close to 0mv except for
3 80mv
10 20mv
16 800mv
17 2.7v
18 2.7
22 3.3v
23 8.2v
24 2.7v
25 2.7v
26 2.47v
U7941
1 3.42v
2 0
3 0
4 3.39v
5 0
6 2.7v
7 0
8 0
As expected, missing SMC_PM_G2_EN. It comes from SMC.
You didn't mention incorrect PPBUS_G3H before...
Check SMC_RESET_L value.
Also try a reflow to SMC.
jpadie
why do you think that PPBUS is incorrect? It is 8.2v.
SMC_RESET_L is high (as per message yesterday).
yes. missing SMC_PM_G2_EN as per the same previous message.
PPBUS_G3H correct value is aprox 8.4-8.5V.
8.2V means SMC don't talk with ISL6259!
And this be caused by SMC, or ISL6259, or something else connected on SMBattery Bus.
As you also miss SMC_PM_G2_EN, SMC is first suspect here.
The best option is change it. But I recommend to reball it first.
jpadie
ah. that is interesting. PPBus has always been 8.2v even when the board was in an S0 state. definitely something fishy.
i will reflow the SMC later. I don't have any stencils here to do a proper reball of a donor.
I did many at hand; there are aprox 150 balls, not too many...
0.35-0.4mm for commodity, but you can also use 0.3, even 0.45mm.
jpadie
ha. it is a plan ... but i am rather middle aged and have shaky hands!
i may try with some old donor boards one weekend!
