820-3209-A - Fan spins high.
gcain
Customer said laptop was in cupboard for a few months. Laptop is suspiciously clean...
MagSafe gets Green & Orange light.
Fan doesn't do the start-stop-start-stop thing; it just turns on then slowly spins faster and faster till it reaches warp-speed.
No backlight or any other signs of life.
I don't even know where to start looking; 99% of my repairs are dead or liquid damage.
PP3v3_S0 = 3v3
PP3V3_S0_HS_COMPUTING_ISNS = 3v274 - 3v28. always moving.
PP3v3_SUS = 3v330
PP1v8_S0 = 1v78
R7402::1 = 360mV
R7402::2 = 8v39
PPVCORE_S0_CPU: 0.816
PPVCORE_S0_CPU_PH1 = 0.822
PPVCORE_S0_AXG = 0;
i ment louis, its 2am there,, if it was me id change r7402 or check voltage on working board
I thought it was an odd question. lol
I don't have a board to test with. It measures right, I think U7400 might be pulling it low?
It wouldn't be the resistor pulling it down, wouldn't U7400 be pulling it down?
Just to check my thought process;
That's why R7402::2 is higher than R7402::1. The resister is restricting the flow, allowing the difference.
If R7402 had 0 resistance (just for example), then voltage would be the same both sides and some component further up the ::2 side of the line would be getting hot.
Board looks spotless.
Fan ramping up is just that the CPU is not running. This one is going to suck probably. I would first try a known good BIOS chip, besides that there is not much you can do if it is not a liquid damage. Save the original BIOS file!
Is it possible to buy the header clip for the diagnostic port?
Would make flashing the bios a lot quicker if I could build a little adapter for it.
Pretty sure you can find it, but it would require research. I have no time to mess with that. I doubt it will be the BIOS though, just a last ditch effort.
I managed to find the connector. I flash these things just often enough that it's probably worth having a jig.
I have two boards now that are doing the same thing.
Should I throw then in the bin, or keep trying?
Thanks for the heads up.
I did experience something similar with a clothes-peg-adapter I built a few years back now. Maybe pulling them off is a cleaner solution.
Once an EFI chip (13"Retina board) cracked in half when it came off and it turned into a nightmare. So I've been reluctant to pull them off unless I have to ever since. Of course you could say it was already compromised which is what lead me to remove and flash it in the first place.
You have 2 boards that have the same? The most common case is liquid or someone stabbed a component off. BIOS is last ditch.....
