820-3209-A No track pad or keyboard
Greg
No signs of liquid damage, Have used a known good track pad. I know this model only uses USB not SPI so should be fixable . Should i check voltages on J5700 with track pad connected? Any known common issues here?
First check L5720 and R5730.
Also check R5704 and U5700 area.
If all OK, I recommend you to test known good TP flex.
Don't trust new chinese flex, try more...
Greg
All those are good area is very clean, Could it just be a bad U5700? have tested with known working TP and TP cable.
Greg
Replaced it with no change. It will do a SMC reset but not PRAM reset. Any other suggestions?
U5700 is not involved in SMC reset.
Check SMC_LID signal.
Did you try the MLB alone, disconnecting LIO flex?
