820-3330-B
Quickfix
looking some help, this board wont turn on with track pad connected, without track pad working fine. tried good track pad and flex same.
where should i start troubleshooting?
Check diode mode to ground on pins 21/22 of J5800, with trackpad connected.
Find some components connected to the same lines, not directly on the connector pins.
Do not apply power to the board, of course...
I'm not sure if I correctly understood you.
Do you mean it turns on with trackpad connected, but R5805 removed?
