I have no idea really. If you shut it down from OSX does it power on again after you connect power? Make sure the option "restart after power failure" is not enabled in OSX. Not sure if this is supported on MacBooks though, it is on desktop machines.
It could be that there is an issue with the RTC power supply. Check if it is present when only battery connected.
