I tried to do a pram reset and it did not chime. I then replaced the backlight driver. Now my backlight output is down to 12.* . I am guessing my solder job may be bad. It seemed to go perfectly
changed the backlight driver and I am back up to 27.8v. Since the speakers are connected to the board on this model, I should be hearing it chime when resetting the pram(but it did not)? I did hear it chime originally when first looking at the computer before removing the logic board
I do get usb light and when resetting the pram it goes off. Is it normal when a logic board with the speakers attached to it, removed from the case, not to chime?
I held the keys and reset the pram several times in a row, it flashed multiple times. I was just asking about hearing the chime if the logic board is pulled out as a second quesiton
