820-3330 pressing power button power on then off
Chuck60
Hi I have a board that I change ISL On and I hit the power button it turns on then off I hit it again and it turns on no issue but it does this every time I power it up.
Does the board turn on by itslef when you connect the charger?
Remove the battery for this test.
Be sure to use 85W charger.
Chuck60
Yes it turn on by itself with out battery I have a original charger that is my test charger verified in system profiler. It’s weird because a PRAM solves it but when I remove the battery for a few days it resumes the same symptoms
