820-3332 A Not recognizing, doesn't see SSD, questionmark folder.
mjanuchta
Hello I have 820-3332 with problem with detected ssd, voltage and resistance in connector is normal, i replace U4510 but still the same, drive was seen when i connect with usb. SSD have HFS. About history of this computer i know that customer put in this bad adapter with this ssd (photos). After this operation, Macbook don't recognizing any SSD in J4501.
SSD_P3V3S0_EN - 3,34V
SSD_RESET_L - 3,34V
PP3V3 S0 SSD FLT - 3,34
This is my first topic, if I do something wrong, please correct me.
mjanuchta
After when I write this topic, i find solution. Problem is in L4500, this bad coil Have 500 Ohms. Customer do short PP3V3 S0 SSD FLT and Coil was burned in half.
Always check real ohm value of a coil in case like this.
You can get normal voltage without SSD, but voltage drops drastically once SSD is inserted.
BTW, welcome to the forum!
