820-3332 PCI driver IOService open error
macfix
When installing OS stop with "check for hardware error " tried several OS version ,different install disks , and know good harddisk but same problem.
I can boot with installed OS but this time crash OS when updating or any app installing
ASD report is;
SATA: SATA PCI Register Test (test #1) - SATA PCI Register Test
- Checks the SATA link error registers for dropped data packets using direct PCI access.
ERROR - -12105 [PCI driver IOService open error] -- TEST FAILED
Any idea?
Corrosion around SSD connector, knocked component, seems to be a communication error, check around U4510 also...
