820-3332 perfect repair, how the ebay repair guy repairs look like....
Repairable
got a MacBook pro in last night. customer bought this MacBook working. after 2 weeks the screen turned off.
he went to the internet (because the seller magicly disapeared) found a repair program for the video issue.
so he send his MacBook to apple. and they declined the repair.
pre fucked something.
wel how beautiful does this look like.
btw i gues he didnt need the other parts on the board
cheap versus exspensive, if i am done ill uploade the image. (if the customer wants it repaired that is)
It's a bit crusty but nothing horrible. Probably an easy fix replacing U9000 and clean up the wires. Maybe swap the LCD connector.
Repairable
yea it does not look like a rabbit hole, and maby i am a bit of a acid pisser.
but would this leave your shop?
no cleaning ultra soon.
everywhere on the board still oxidation.
small capps looking like they will die next week.
and just dipping the wire against a leg.......
I at least clean all the corrosion off. I usually don't bother to clean up flux unless it is really bad. The caps in the picture look ok, I would not have touched them.
Repairable
No indeed the ones with the wire on are good.
It is on the Other side of the fan on the edge they are crispy black on alot of sides.
Even the pads where crispy
