820-3435-B not detecting battery
TBFix
I had a bit of spillage on the board but nothing around smc or charging Ic. What diode reading should I be getting around C7117 (PPVBAT_G3H_CHGR_R) Im getting 0.113v on diode. Im getting 8.6v on Q7155 pin 5
That value is good.
Do you get correct PPBUS_G3H voltage?
Check it without battery.
Check R6950 and post voltage and diode mode to ground on SCL/SDA lines of battery bus.
TBFix
PPBUS_G3H is 8.59v without battery
r6950 is fine at 10k
Scl/Sda lines are 0.445v diode mode and 3.3v on both
I dont have another battery to verify if battery is bad.
TBFix
As this had water damage as previous mentioned I wanted to make sure board was reading ok before buying a battery as they are expensive and I dont see many 11" mac air's.
