820-3435 liquid damaged
arnonabuurs
This board came in with no light on charger. Liquid at U7090, which I replaced and 3.4v came back. PPBUS = 8.6. More liquid at R7180, replaced and C7400 and C7425, resoldered U7400 as pin 12 had a tiny bit of corrosion on it.
The boards now gets green and orange light, I have 3.3v and a 5.1v pulse at C7518. PPVRTC = 3.3v. On U6100 I got 3.3v and area looks clean. U1950 has 3.4v and all_sys_pwrgd pulses at 3.3v but goes to 0. CPU Vcore also pulses. I cannot find any shorts. I did replace U7501 but situation is the same. U1900 has 32mhz clock. Ideas?
Pin3 of U1950 pulses too?
Try new BIOS clean ME.
And check for corroded component, or trace.
Put good flux and heat SMC and CPU; no more than 180-200 degrees.
You may need to ultrasonic too.
