820-3437-A "possible bad CPU?"
(On a side note. "why won't my bios programmer read any of these boards?") Reads 820-4347-B just fine.
I have a 820-3437-A
board was sent to me for "no back light" after the repair shop did a sonic cleaning for water damage.
The damage areas were around the ppbus g3 hot area and some around the display parts on "top side"
I did not see any parts or trace damage beyond surface damage. I did check closely and pick at parts.
Green light
fan spin
all S0 rails are up
Current draw is low 0.250 mA (0.500-0.600 is what I normally see on these)
Back light EN signal from CPU not present.
No display or back light on the screen.
machine appears to not boot.
Could this be a CPU.
There could many things.
A single corroded, or knocked off resistor is enough to stop the board working.
Usually ultrasonic cleaners knock off components; especially if no sweep function used.
Also UC will not rebuild a corroded trace!
No reason to check for video, if nor even USB activity is present.
Don't use MacBook charger.
Just inject external 3.3V on 3V3_SUS line of the board.
