820-3437-B battery problem
interaptiva
Hi everyone, I have a 820-3437B with a strange problem: It has a liquid damage, does not start without a connected charger, the LED turns orange and the battery always remains at 0%.
I checked if there was oxide on the board, I cleaned everything and I did a 150 ? reflow on the SMC chip. for a few minutes it came back to work properly and the battery charged with normal percentage increase but then the problem recurred.
I removed the SMC chip and reballed but I did not solve it.
using the original battery this is not recognized, using a compatible battery is recognized but remains at 0% and lightning appears on the battery symbol.
Q7155 I have B GATE and PPVBAT_G3H_CHGR_R at 8.6Volts when the charger is connected
on PPVBAT_G3H_CONN I have 7.17Volts and it does not increase
Can you help me? thank you
Post diode mode to ground on both SCL/SDA lines of battery bus; also voltage.
"It has a liquid damage"
Which area?
You may need to remove and clean the battery connector; even to change it
I forgot to mention, post exact voltage for CHGR_A/BMON; both charger and battery connected.
Also post exact ohm value (measured onboard) for R7180/81.
interaptiva
the liquid damage was very light, there was a little oxide on the trackpad / keyboard, but nothing was visible on the board.
resistance on pin 17-18 -------- 3.6 ohm
resistance on pin 27-28 --------20.0 ohm
PPBUS_G3H is 8.60 Volts without battery, only charger
R7180 ------- 100k correct
R7181 ------- 62k correct
interaptiva
I tried several batteries, only with one in particular is detected. the others are not recognized. what is detected remains at 0% on the system info the battery is present but is not charging. the lightning bolt appears on the battery symbol at the top right
JohnB8812
Ok so the lightning bolt doesn't change over and says "Battery is not charging"? If so, I suspect maybe a bad ISL6259
