820-3437-B No Boot
LCDR2
Hi All
This is what I know.
PPBUS_G3H - 0v
PP3V42_G3H -0v
CHGR_UGATE 4mv
CHGR_LGATE - 0mv
U7100
1 -.39mv
2 18.16v
3 4.82v
4 330mv
5 0.4mv
6 0v
7 0.4mv
8 0.3mv
9 33.1mv
10 330mv
11 330mv
12 332mv
13 13.4mv
14 330mv
15 11.5mv
16 0v
17 7mv
18 7mv
19 5v
20 5v
12 0v
22 0v
23 7mv
24 7mv
25 4.77mv
26 17.65 mv
27 18v
28 18v
___
Resistance R7105 20ohms
Resistance U7100 (17/18) - 3.5 ohms
Resistance U7100 (27/28) - 20 ohms
LCDR2
Could U7090 be a problem? I went down the rabbit hole of U7100.
The hot spot is about 38 degree..
LCDR2
L7130 - 0.131
L7095 - 0.000
Tested Red to ground and on both sides of chip.
Does that Mean I have a short on PP3v42?
u7090
1 - 0.6V
2 - 335mv
3 - 1.6444v
4 - 0.542v
5 - -
6 - 17.52v
7 - -
8 - 17.54v
9 - -
For sure...
Safe to inject voltage there; start with 1V and go up if needed, no more than 4V.
Don't forget to set current limit at max on your PSU.
LCDR2
Hello
So I have removed L7095 and the short is on Pin 2 not pin 1, so does that rule out issues with U7090 ?
Just to confirm before I blow up the board...
Positive is soldered to Pin 2 of L7095
Ground is soldered to a nearby screw hole
Power Supply is set to 1v
Amps is set to max 5 (that's it's max)
... and I am looking for what gets hot using alcohol or the thermal camera?
Is time to change the SMC.
However, check again diode mode there, once SMC is removed; before soldering other chip.
LCDR2
I have checked Diode mode again, I get 0.337. Is it worth re-balling old SMC, or do I just go straight for a new one?
Always use SMC from donot board, to prevent any issue.
3476/3536 SMCs are interchangable, but not sure about other good equivalency.
