820-3437-B SPI Bios chip replacacing
air_chair256
Thanks heaps i programmed the Bios with this file and it worked, thanks so much for your help, i would appreciate if you answer one more question please: so in next time if i face same problem do i need to create a clean ME and write the serial in a working Bios and install it and it will work?
thanks
The way to create a clean ME as found on various websites is completely wrong, they have no idea what they are doing. It will break many things including webcam, LAN, etc. Just editing the serial number will give an error when you run a hardware test as the checksum on the Fsys block is no longer correct.
Explaining how this all works is way too complicated for the few times you may need this. The easy solution is to buy a "Medusa" from Chipmunk so you can mess around with it yourself. They are not cheap though! It will however fix the ME, correct Fsys checksum and remove EFI lock, etc.
http://www.cmizapper.com
