820-3437-b spillage
TBFix
This board initially was only drawing 20ma After changing a few components I now have all s0 rails up. Fan spins unit draws 150ma (Occasionaly jumps to over 250ma thern drops back) but no usb activity/Chime.
I have reballed the smc and tried a bios file from a different forum
(couldnt find one here)
ppbus_g3h is 8.58
pp3v42_g3h is 3.42
PPVcc_S0_Cpu 1.7V Cpu doesnt get warm.
Smc bypass mode draws same current.
TBFix
Hi thanks, many places over the board.
I trawled through many posts looking for a link to known good bios dumps for this specific board and couldnt find any.I replaced so far u7200 corroded and no cpu vcore before replacement, C102 was short, U1950 had .5v on pin3 before changing it, Spillage under Smc so reballed it (Might replace it and see if it helps). U7400 had corrosion and broken trace on it so replaced and fixed trace.
First symptom was 19ma no charger led so current situation is 150ma, fan spin No Usb activity.
All spi resistors checked ok.
Will try one of those bios files .
Do you think there is any point in replacing the Smc? I had a 00165-a recently with something a bit similar and I replaced the Smc and it worked.
All diode reading
L7320 - .0319
L7310 - .0314
L7630 - .099
L7430 - .136
L7560 - .352
L7520 - .418
L7130 - .143
L3095 - .476
L7701 - .418
tried those dumps but still the same.
"Heat CPU using quality flux."
"lighty reflowed underside of Cpu/Pch" will not burn eventually crap accumulated underneath CPU...
TBFix
What I meant was I heat the underside of the board and used original nc-559 flux and reflowed the cpu/pch then afterwards ran ipa under the cpu
