820-3437 black spots left side only
gadgetfix
Hey all. a1466
History: waterdamaged
- ultrasonic cleaned
- inspected under micro scope
everything seems ok but i have a problem with lcd backlight. it seems to have waves/black spots. it only come half way on the lower left. Is it possible to fix?
No need to check the resistors, just diode mode all the LED return pins on the LCD connector. They should all read the same. Could be corroded connector/resistor/trace or LP8550.
gadgetfix
i measured all 6 pins they are all around 626~631
no sign of corrosion - water was more on the top side of board + the other end so i suspect it would be LP8550.
I will replace and report back.
Thanks for your help.
gadgetfix
cry me a river. had LP8550 mounted upside down. soldered it right way now boots but no blacklight? wonder why? :rolleyes: :D:D:D
