820-3437 - Bluetooth not available.
gcain
U3510::5 is getting 3.4
::10 = 3v
::9 = 0v.
Not sure what I should be seeing. At what point does it get turned on?
9 = 734
10 = 677
6 = ol
7 = 361
Would Pin6 be the chip or the trace?
How can I run a jumper?
There are no points along the way, it goes from there straight to U0500.
Scrape off pad 6 and 7 under U3510 then run wires from pin 6 and 7 to TP_USB_5P and TP_USB_5N respectively.
If I run a jumper wire from pin 6 to TP_USB_5P I get no picture.
Remove the jumper and the picture comes back.
Gotchya.
Thought I was jumpering.
If the existing lines are affecting it, are they really broken?
