Dozer
got this macbook air with liquid damage
cleaned it in ultrasonic, after visual inspection dont found anything what immediately catches the eye
orange/green light on macsafe
3.42V present
PPBUS_G3H is 1.5V
open the F7140 is 8.52V
there is no short to ground in PPBUS_G3H but i can measure only 0,110 in diode mode, should be about 0,165
pulles out F7700 but same result
measured resitance on L7130, about 150 ohm, a good board shows about 500
with thermal camera i found Q7630 goes about 45 Grad Celsius
After replacement of Q7630 I go 500 ohm resistance and a fan spin
but seems still like brain death, measured on the U6100 pin 5, 6,7 got in diode mode high value (more than 1.04...
Tryed another u6100 from 820-3437 programmed it with the clear me , now, diode values are good. starting the board fan is spinning, after about 8 sec it turns off and start again
soldered back the "old" u6100, now here the values pin 5,6,7 are good as well
but board starts and thats it fan spins, after a while with full power, nothing happens and no cycling.
need some help please
3.42V present
PPBUS_G3H is 1.5V
