820-3437 Missing SMC_SENSOR_PWR_EN
mdc2018
Machine gets orange light, no fan spin.
Found it was missing PP3V3_S4SW_SNS.
I tracked this back to U8050 and found that U8050 was not getting SMC_SENSOR_PWR_EN.
I found that the SMC Creates the SMC_SENSOR_PWR_EN signal.
I changed this SMC and still have the exact same issue, nothing has changed.
Any Idea?
That signal appears later.
Did you check first signals from the power on sequence?
Try to start in SMC bypass, if you think about sensors error...
mdc2018
How do I perform an SMC bypass, image assuming it is different than an SMC reset?
And yes ,I worked my way down power rails everything appeared to be present until I hit PP3V3_S4SW_SNS
