Hello, got this 3437 that has a 3 time fan spin but no display. When I do a pram reset display flashes and reboots normally. Backlight is turning on it has 24v but no image appearing. Any suggestions?
problem solved, i just had a customer coming in with the same issue. His harddrive was fried, some black IC, shorting the 3.3v line i guess. Removed the drive and worked. I took the drive out of this one, works as well ! So 2 macs fixed
