820-3437 No Fan Spin
fodelement
Hello!
I have always interested in component level repair, so when the opportunity to get a liquid damaged Mac Book Air arrived, I was delighted. So bear with me, as this is my first attempt at this.
I have a Green/Orange on the Mag Safe, but no fan spin.
Below are my voltages.
PPBUS G3H = 8.58
PPBUS_S5_HS_COMPUTING_ISN = 8.58
PPBUS_S5_HS_OTHER_ISNS = 8.58
PPDCIN_G3H_ISOL = 15.13
PPDCIN_G3 = 15.13
PP3V42_G3H = 3.44
PPVRTC_G3H = 3.33
PP5V_S5 = 5.2
PP5V_S4RS = 3.34 Pulse
PP5V_S0 = 3.14 pulse
PP3V3_S5 = 3.33
PP3V3_S4 = 0.33
PP3V3_SUS = 3
PP3V3_S3 = Pulse 2
PP3v3_S0 = Pulse 1
PP3V3_S4SW_SNS = Pulse 3
PP3V3_S0SW_SSD = 2.3
PP3V3_S4_TBTAPWR = Pulse 3
PP1V8_S3 = 1.7
PP1V2_S3 = Pulse .70
PP1V05_SUS = 1.06
PP1V5_S0 = 1.5
PP0V6_S0_DDRVTT = Pulse .34
PP1V05_S0SW_PCH_HSIO = 1.05
PP5V_S4RS3 = Pulse 3.34
The little corrosion I found was near U6100. I cleaned with with isopropyl alcohol. I measured all 16 terminator resistors and they are fine. The only issue I can find (besides the voltages) is Pin 2 on U6100 (SPI_MLB_MISO), does not have continuity with R6114, R6123 or it’s VIA (824). My questions are…
  1. Should I be getting continuity from those locations? If so, is re-soldering the chip/replacing is my next step? I know it’s a BIOS chip, so it’s not a simple rip and replace.
  2. Is 15.13 too far out of tolerance for PPDCIN_G3H_ISOL/PPDCIN_G3 which should be 18.5?
  3. If I understood Louis's Rossmann Repair Training Guide correctly, should all of the rails be pulsing?
  4. Any other suggestions as to what I should look into?
PS: PS:32 > IS:24 > Wagner 08 :)
"PP5V_S4RS = 3.34 Pulse"
Never post DC voltage for a pulsing rail.
Only an o-scope can show you the peak voltage there.
"Is 15.13 too far out of tolerance for PPDCIN_G3H_ISOL/PPDCIN_G3 which should be 18.5?"
Don't bother with that; actual value depends of the charger used.
"PPBUS G3H = 8.58"
This is what you really need.
"Should I be getting continuity from those locations?"
YES, if you want to start the board.
Don't waste time in other thing, before solve tis issue first...
fodelement
Hello,
Thank you for this information! I had a feeling this was an issue, but did not want to chase down something if it was not an issue.
Would removing U6100 an putting it back on/replacing it be the best way to resolve this issue? Or should I try something else?
I tested for continuity from
U6100 Pin 2 to via 824
U6100 Pin 2 to R6123 Pin 2
U6100 Pin 2 to R6114 Pin 2
via 824 to R6123 Pin 2
via 824 to R6114 Pin 2
None of which had continuity.
​​​​​​​R6114 Pin 2 to R6123 Pin 2 does have continuity.
I was supposing that.
You mean TP[1]SPI_MLB_MISO.
Is just a test point and you can run wire from it to U6100, or R6114/23, depending where the trace is broken.
BTW, "Probe: 824" (maybe Via 824 in your boardviewer) appears for all the points of that trace...
