820-3437 RAM Beeping
No-Clean
820-3437 clean board RAM beep sound at startup, I already gave the 4 RAM chips a reflow but same issue.
I don't thinks this boards are known for RAM issues, any guidance will be greatly appreciated.
You are not the first with same in issue in this board.
Could be bad RAM chip, which cannot be solved by reflow.
Can also be broken trace/solder under CPU, or a RAM chip.
You can try reball, or change RAM chips.
This will not help if problem is on CPU side...
