820-3437B Not charging
OSX reports battery percentage?
Does it start on battery alone?
Use another battery, with some charge, for this test; if original is drained.
Post CHGR_A/BMON with board on/off and battery present and not.
Bouba148
Yes OSX reports percentage
Yes it's starting with the battery alone
I'm using a battery charged at 70%
Board OFF with Battery Only:
CHGR_AMON: 0.00V
CHGR_BMON: 0.049V
Board ON with Battery Only:
CHGR_AMON: 0.00V
CHGR_BMON: 0.100V
Board OFF with Battery and Charger:
CHGR_AMON: 0.660V
CHGR_BMON: 0.00V
Board ON with Battery and Charger:
CHGR_AMON: 0.880V
CHGR_BMON: 0.49V
"CHGR_BMON: 0.49V"
Looks like battery is charging.
At least this signal shows battery receives current from MLB.
Unless you have a problem with R7150-52, or traces to pins 17/18 of U7100.
Bouba148
Just to let you know that the problem is fixed.
Now with the board ON it's pulling almost 3 Amps, CHGR_BGATE stays low and pulsing like before.
I can see the percentage rising quite fast.
I fact, I think that in all the things I did, one of them solved the issue except that the battery was continiouly showing 1%. This one is dead.
So I replaced it with another one now it's charging normally.
Again thanks for your support and patience
You can set this Topic as Solved. but i you could just answser to the question regarding the battery logos......thanks
Best Regards
Left side logo shows battery is charging.
Right side not charging, probably "Replace now" advice in drop down list menu for battery...
