The macbook boots up and runs. ASD EFI passes but ASD OS has 2 thermal errors "unknown result code -- test failed" and the fans are constantly running full speed.
This macbook had liquid damage, I replaced a couple of resistors near the SMC R5092 and R2502 and ran a jumper from pin2 of R5092 to PP3V42_G3H as that pad was gone. The only other corrosion I could find was a little inside the thunderbolt connectors.
I tried another heatsink and thermal paste and checked that U5570 has 3.3V on pin1. Could this be a problem with the SMC?
