820-3462 - MacBook Pro Keyboard / Trackpad Not Functioning
Check R5701/02/04.
Be sure to have TPAD_VBUS_EN present.
Also check BUTTON_DISABLE.
Do you get correct powers at J5700?
mccafe
Here are the readings.
R5701 - fluctuates 0.5 - 3 volts
R5702 - 0.00 - 0.02 cycles
R5704 - 3.3 volts
TPAD_VBUS_EN - 3.3 volts
BUTTON_DISABLE - 0 volts
Going to see what's the issue with R5701/02
If both resistors have good ohm value, change U5701.
There is USB line, complementary voltages; do nor expect 3V on both data lines.
Problems with other USB ports/devices will point to U2700 problem.
mccafe
Okay, I will replace U5701. Must I get it from the same board number? Are there any other boards I can take it off of?
I noticed 820-3115 and 820-2936 have same
CY8C24794
337S2983
MLF
SYM_VER2
Does this mean they have similar firmware?
mccafe
The power rails for the keyboard is steady.
Here's something odd I found. When I disconnect the trackpad flex cable, the WS_KBDx signals are steady and the keyboard is very responsive. As soon as I reconnect the trackpad + flex cable, it jumps up and down. When I leave the trackpad flex connected and disconnect the actual trackpad from the flex cable, the WS_KBDx signals are steady. Tried new trackpad + new flex cable.
Looks like I'll need to order a trackpad connector and try that out.
Be aware of new flex from China; some people complained, needed to try 2-3 untill find good one.
Test continuity from MLB to trackpad board, when flex is connected.
You can also compare diode mode readings on the connector (TP connected), with a good board.
mccafe
Okay, so I did more tests and then found that WS_KBDx signals + pin 2 / 9 of the TP connector (Z2_CLKIN & Z2_SCLK) were fluctuating regardless of whether or not TP is connected. I was convinced that maybe something was in the TP connector (because why all of a sudden is it acting like this after reconnecting flex cable several times?) so I ended up removing it.
Now that it has been removed, it's still fluctuating with no keyboard connected, no TP connected (obviously) and now I have a board with no TP connector! I am having some difficult sourcing out the part online. Now everything is pointing back to a controller issue which I replaced 3-4 times already.
