820-3462 PP5V_S5 0.8V
No-Clean
Board had very little corrosion on U7201, replaced it and now PP5V_S5 is only 0.8V
Resistance on pins 17-18 and 27-28 of ISL6259 is correct
ppbus is 12.6V
U7201:1 12.6V
U7201:12 3.4V
U7201:4 3.4V
U7201:21 3.4V
Already check for shorts and all is ok.
"U7201:4 3.4V"
Are you sure about this?
Is really strange, if 5V_S5 is not present; means no 3V3_S5 also.
Post again basic U7201 voltages; pins 23, 12, 13, 22, 29, 21, 4.
Do you get (or not) L7260 voltage?
No-Clean
Thanks, I measured wrong, U7201:4 is 0.8V
U7201:4 0.8V
U7201:12 3.4V
U7201:13 1.3V
U7201:21 3.4V
U7201:22 5.8V
U7201:29 0.8V
No voltage on L7260
No-Clean
As stated in the description, U7201 was already replaced, but just in case I just replaced it again, but same measurements.
