820-3462 wifi disabled, keyboard partially working
Bouba148
Hi Team,
I have a 820-3462 with trace of liquid damage. cleaned with the Ultrasonic cleaner
I already fixed the backlight.
I had fans running at full speed: issue coming from the camera, now i've disconnected it and fans runing normally (all temp sensor reports normal temperatures)
Now i'm facing to 2 weird behaviors:
Regarding the keyboard: only few keys are working, the Trackpad works correctly.
Taken Actions:
Replaced the keyboard, and it's the same, with the same keys working. the Alt key is ok ( i can select the booting hdd)
Regarding the wifi:
when in the OS, it scans (wifi logo in action) but can't detect any network, when i click on network preferences, there it reports that the wifi state is disabled, when i click on enable it stays disabled.
Also if i go in the assistant wisard, there it can detect the surounding networks but can't register to any of them.
Hardware detected, Mac Adress OK
It can resgister to a network previously connected to.( same OS session with another macbook pro).
Beside that the thunderbolt brigde is connected.....how is this possible?
Could it be a kind of blacklisted motherboard? don't think so as I also replaced Airport card
Taken action:
Replaced Airport card with original RIO board: NOK
Replaced RIO board with original Airport card: NOK
Replaced Both together: NOK
I've mesured the differents voltages related to the Airport (AP) and WLAN, they seems all OK
External USB devices (flash drive, keyboard) : OK, I'll have to test the HDMI port.
Question:
Could both issues have a link? if yes i would redirect myself to U2700 (USB HUB Internal Devices ) and its surrounding area.
Could both issues + the camera have a link? that would redirect me plus to the U1800......
Maybe a communication signal is missing. Could it be related to the OS? as i'm testing it from installed Sierra USB 2.0 Flash drive (unfortunately i don't have an ssd for this board)
If you want me to take a specific mesurement feel free to ask.
I will also try from an OS installed on USB 3.0 hdd, and also will try the bluetooth asap and update.
Bouba148
Hi Dukefawks, thanks for your reply
here are the mesurements in diode mode with the red probe on the ground
With the machine OFF magesafe not plugged and the keyboard NOT connected
1: 0.448v
2: 0.448v
3: 0.449v
4: 0.321v
5: 1.098v
6: 0.705v
7: 0.703v
8: 0.704v
9: 0.702v
10: 0.703v
11: 0.696v
12: 0,700v
13: 0,701v
14:0,768v
15:0,702v
16:0,702v
17:0,701v
18:0,702v
19:0,701v
20:0,702v
21: 0,701v
22: 0,702v
23: 0,702v
24: 0,702v
25: 0,703v
26: 0,702v
27: 0,703v
28: 0,702v
29: 0,00v (normal it's ground)
30: 0.368v
with the machine ON with the DVM in DC Voltage mode :
4: PP3V42_G3H 3,410V
30: PP3V3_S4: 3,350V
With the keyboard connected:
1,2,3 turn to 3,39V when shift,ctrl,cmd key are pressed
4,5: always 3,4V
13: 0v
When the machine is ON with OS on usb2.0 flash drive:
Cap key led doesn't turn ON when pressed
6,7,8: 0V
9,10,11,12,14-24: 3,34V
25,26,27,28: 0V
When the machine is ON with no booting device (question mark)
Cap key led turns ON to green when pressed
6,7,8: 1,12V
9,10,11,12,14 to 24: 3,22V
25,26,27,28: 3,28V
30: always 3,35V
Just to let you know: i've ordered the ssd+flex ribbon+caddy to test it in "normal" conditions and not from OS installed on USB2.0 flash drive
Regarding the RIO flex cable , I have no guarantee that the one I tried is 100% Good.
Best Regards
Diode readings look fine so the connector may be suspect. Inspect the pins carefully, was there any liquid in the connector?
Bouba148
Update:
I've checked for no cut track from J5713 all pins properly connected where they're supposed to be.
Maybe bad "new" connector
Again, check diode mode on all pins of the keyboard connector and compare to previous measurement. Is it a known good keyboard?
Bouba148
Hi Dukefawks, I've ested all pins in diode mode and i have the exact same reading like previously which seems to be ok.
I've also tried another keyboard which is doing the exact same symptoms ("9" "O" "L"... not working) , that'swhy i've ordered another keyboard connector.
So i'll update you asap.
Thanks
Bouba148
Hi Dukefawks
Here is the Last update regarding that board:
I changed the keyboard connector and with the original keyboard(liquid damaged) many Keys doesn't work but the POWER bouton is OK.
With 2 others keyboards (1new the other used) :
ALL the Keys are working except the POWER bouton.
I'm out of idea, i will ask for another New keyboard to be sure.
Do you have any clue ?
If you are not sure if you have a known good keyboard then there is no sense in fixing a board that does not have an issue. Any retina/Air KBD is compatible for testing if you have anything lying around.
