Bouba148
Hi Team,
I have a 820-3462 with trace of liquid damage. cleaned with the Ultrasonic cleaner
I already fixed the backlight.
I had fans running at full speed: issue coming from the camera, now i've disconnected it and fans runing normally (all temp sensor reports normal temperatures)
Now i'm facing to 2 weird behaviors:
Regarding the keyboard: only few keys are working, the Trackpad works correctly.
Taken Actions:
Replaced the keyboard, and it's the same, with the same keys working. the Alt key is ok ( i can select the booting hdd)
Regarding the wifi:
when in the OS, it scans (wifi logo in action) but can't detect any network, when i click on network preferences, there it reports that the wifi state is disabled, when i click on enable it stays disabled.
Also if i go in the assistant wisard, there it can detect the surounding networks but can't register to any of them.
Hardware detected, Mac Adress OK
It can resgister to a network previously connected to.( same OS session with another macbook pro).
Beside that the thunderbolt brigde is connected.....how is this possible?
Could it be a kind of blacklisted motherboard? don't think so as I also replaced Airport card
Taken action:
Replaced Airport card with original RIO board: NOK
Replaced RIO board with original Airport card: NOK
Replaced Both together: NOK
I've mesured the differents voltages related to the Airport (AP) and WLAN, they seems all OK
External USB devices (flash drive, keyboard) : OK, I'll have to test the HDMI port.
Question:
Could both issues have a link? if yes i would redirect myself to U2700 (USB HUB Internal Devices ) and its surrounding area.
Could both issues + the camera have a link? that would redirect me plus to the U1800......
Maybe a communication signal is missing. Could it be related to the OS? as i'm testing it from installed Sierra USB 2.0 Flash drive (unfortunately i don't have an ssd for this board)
If you want me to take a specific mesurement feel free to ask.
I will also try from an OS installed on USB 3.0 hdd, and also will try the bluetooth asap and update.
Taken Actions:
Regarding the wifi:
Taken action:
Question:
