820-3476-a A1502 Fixed blown cap and resistor and still has issues.
Cire3
820-3476-a
A1502 Fixed blown cap and resistor and still issues.
Came in no boot. Removed logic board and found C7536 blown, C7537 and R7536 looked like hell.
Replaced them both, and unit had fan spin. Reassembled unit and no boot ?
Ok, let's take it back apart. Power supply shows 0.09A draw. Light goes green, then orange. After a quick wander, again 0.09A
What I do find odd, SSD gets warm, however no chime, no fan and CPU is cold.
Thoughts from here?
So you have only 3V3_S5; what about 3V3_SUS?
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
Cire3
Checked 3v3_SUS @
U6100 pin 8 ,C6100, R6101, U8130 Pin 2, R8133, R1583, R1581, R1590, R1580, C1206, C1202, C1204, R1549, R152.
All pined @ 3.3V
I'm a bit green.. Would need help with " Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L "
Not sure how this is done?
I hope this thread helps you:
BTW, no need to measure the voltage of a power rail in more than one point.
In case you detect drop pulse on PM_PWRBTN_L, check for pulse at PM_SLP_S4_L too (at same time).
Cire3
That document most definitely helped me, big thanks ! Do we have an area for docs like this ?
PM_PWRBTN_L, check for pulse at PM_SLP_S4_L : Both pulse when I ground SMC_ONOFF.
It drawn a little more power briefly, then goes back to drawing 0.09A
Check for pulse at all big coils; at same time when trigger SMC_ONOFF_L.
Also check ALL_SYS_PWRGD for pulse.
Inspect U1950 for corrosion.
Test strating in SMC bypass mode, just in case.
