820-3476-A no audio (no chime, no audio devices detected)
protocold
Other than sound. Everything else seems to be ok so far.
C6411 got knocked off and U6410 seems to have a little chip around the corner (at pin1)
U6200:
pin 1 (PP4V5_AUDIO_ANALOG) = 4.5v
pin 3 (4V5_NR) = 1.2v
pin 4 (4V5_REG_EN) = 3.3v
pin 6 (4V5_REG_IN) = 5.1v
PP3V3_S0_AUDIO_ANALOG - 3.3v
PP5V_S0_AUDIO_AMP_L - 5.1v
PP5V_S4_AUDIO_XW - 5.1v
L6300 = 1.5v
protocold
checked R6331. R1310, R1311, R1312, R1313 they are all good. Is there any other that I missed that I should check before changing U6201?
If audio codec is still not detected, then bad chip/solders.
Also check all resistors and traces from its area; even on the other board side.
