820-3476-A No Backlight
No backlight
Some readings
U7700
Pin 1&2 LCDBKLT_SW = 0.1v
Pin 4 LCDBKLT_FET_DRV = 0v
Pin 5 PP5V_S0_BKLT_D = 5.15v
Pin 18 PP5V_S0_BKLT_A = 5.15v
Pin 17 BKLT_EN_R = 3.34v
Thank you
"12.38v bklt_sd
If good"
Is NOT!
Did you try another compatible LCD assembly?
Check R7750-53 and traces.
Post voltage and diode mode on SCL/SDA lines.
What should BKLT_SD be to be good? LCD Assembly good tried on working MacBook.
BKLT_SCL = 4.62v 0.468
BKLT_SDA = 4.54v 0.464
R7750 to 53 all good. Traces appear fine.
Backlight adjust is controlled through I2C bus, via PCH -> T-CON -> U7700.
BKLT_SD must be 0V, in working state; controlled as mentioned.
Try chabging U700.
Check all its connections.
Be sure no short anywhere.
If you mean U7700 then I have changed it but the same problem persists. Thanks
I will check to see if there are any shorts to its connectors
Yes all readings were carried out WITHOUT screen connected.
Shall I do them again with screen connected and send them too you?
Of course.
How do you expect to get backlight voltage, if no LCD connected.
I already explained you the via for required communication; T-CON is inside LCD assembly!
There was a short on PPVOUT_SO_LCDBKLT caused by a bad LVDS connector. Replaced connector and now all good. Thanks again for your help and support. Until the next one - Adios!
