820-3476-A Only safe boot works
macfix
Hello
I m working on 820-3476-a few months ago liquid damaged and cleaned by another service. Board worked 1 week only then stopped .
Machine working only safe mode (when you press shift key machine booting) other way when you see desktop or login screen freeze computer.
Tested known good , OS with external and internal disks , keyboard,trackpad, battery.
I can install OS without problem but when start to login screen freeze again..
When checked board saw bios touched some one so tried 3 different bios with my older used file (also clean me bios )
ASD starting freeze restart computer:(
Any idea about this situation ...
Safe mode working would suggest it is a device driver hanging the system. Remove everything not needed for booting and try booting the bare board. Check corrosion around CPU Vcore supply and SMC.
