820-3476 Bootloop (but sometimes turns on)
arash
It had Liquid damage all over it.
The Fan spins for 1 sec and stops. Then it starts again, to do the same thing over and over again. Sometimes (Especially if we start it for the first time after a long time) it boots, no problem whatsoever.
We already replaced EFI chip after ultrasonicing it, bot no success.
Remove battery, unplug charger, press power button, plug charger and maintain power button pressed 5-10s.
You can use R5115/16 pads instead of power button...
"Fanspin steady"
So board stays on in SMC bypass, but not working?
Did you test USB activity?
Check if all big coils get voltage.
