rany
This is a rush job, I have no time to investigate properly, and hoping for clues.
We always have display on external monitor, sometimes we have on the internal display, sometimes not. We booted three times, only last time did we get display from internal monitor.
Customer said most times pulling the external monitor leads to having display on the internal monitor.
Internal screen tested with another board, worked every time. Could be a coincidence?
Board does not show any trace of previous repair and no corrosion anywhere.
Screen connector looks good, board connector looks good. Poking at the screen cable does not cause display to come and go.
Hall effect resistor (0 Ohm) is ok. Hall effect component is present and measuring across same as a donor board.
I have continuity from resistor to SMC 100K resistor.
Any clues on where to start are highly appreciated. TIA.
