This board had a very small unique spot of water on bottom side near audio chip.
The rest of the board is intact, I replaced keyboard because some keys were not working anymore.
Laptop works perfectly but with EFI I have IPBR over high limit error when only battery.
When battery +charger plugged in I have no errors when I run EFI.
I inspected ISL area with sensing resistors on pins 17-18 (4.6ohms) and 27-28 (20,8ohms) and R5429 300kohms.
IPBR value reported is 1.984A. Normal range should be [0.0-1.5]A.
Except a bad battery I don't see anything else that may cause this error. I went over one complete charging discharging cycle and it holds charge a good 6 hours with full screen video and apps running, nothing heating.
Any advice beside trying antother battery tomorrow?
